Is it possible to disable one of the options in menu for a particular user in Thingworx 8.5
As per my understanding you can give permission to complete menu, not to the menu item for particular user to visibility and run/design time. There is only option to add user group in it.
Suppose a menu contain 5 different items, all items have different mashup links. Then all 5 users can see that menu and menu items and click on it.
You can give permission of mashups for different-different users.
Hi @Ujwal17
Thank you for opening this post on the Community. Did you check use permission options in the menu for this?
Please brief it a bit more.
Mohit
Consider there are 3 options in menu as
option1
option2
option3
option2 has to be disabled(similar to a disabled button) for user X. whereas, it has to be accessible for all the other users
is this clear?
Also yes, I checked the permissions for menu. means, I just denied the visibility permission for the mashup link in option2 for user X. So, when he clicks, a status showing
'permission denied' comes in the page. But , user X can still click on the option2. I want to make it non-clickable for user X
Hi @Ujwal17.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
