I am trying to merge 9 Infotables into one. Right now I am using Union to merge two at a time, then merge the resulting tables together. Does anyone know of a more efficient way to do this? All of the infotables have the same data shape.
var result12 = Resources["InfoTableFunctions"].Union({t1:result1,t2:result2});
var result34=Resources["InfoTableFunctions"].Union({t1:result3,t2:result4});
var result56=Resources["InfoTableFunctions"].Union({t1:result5,t2:result6});
var result78=Resources["InfoTableFunctions"].Union({t1:result7,t2:result8});
var result14=Resources["InfoTableFunctions"].Union({t1:result12,t2:result34});
var result58=Resources["InfoTableFunctions"].Union({t1:result56,t2:result78});
var result18=Resources["InfoTableFunctions"].Union({t1:result14,t2:result58});
var result=Resources["InfoTableFunctions"].Union({t1:result18,t2:result9});
Hi Andrew Gondek
You can refer below existing Knowledge base article and Community Thread to Merge info tables.
How to Merge InfoTables in ThingWorx
How can i merge two infotable and output as one infotable?
Hope it helps.
Hi Mohit Goel
Those articles are where i started exploring this topic and do not answer my question of how to merge more than 2 infotables at a time.
Try this, the following works for every vector length.
pip[i] = //your vector of infotables
function mergeDinamic(tab1,tab2){ var params = { t1: tab1, // INFOTABLE t2: tab2 // INFOTABLE }; // result: INFOTABLE var mergeok = Resources["InfoTableFunctions"].Union(params); return mergeok; } var params = { infoTableName : "InfoTable", dataShapeName : "your datashape" }; // CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(DSHP_STREAMSTORICO) var mrgok = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params); for (i=0;i<pip.length;i++) { if (mrgok.length === 0) { if (pip[i] && pip[i+1]) // check if the object exixt { mrgok = mergeDinamic(pip[i],pip[i+1]); i=1; } } else if (mrgok.length > 0) { if( pip[i] ) // check if the object exixt
{ mrgok = mergeDinamic( mrgok , pip[i]); } } } var result = mrgok ; //INFOTABLE with the same datashape
bye
