I download the JDBC Connector from marketplace :
https://marketplace.ptc.com/apps/195356/jdbc-connector-extension#!overview
But uploading the driver file doesn't work with JdbcCreator, nothing happens after clicking choose file , while the standard upload widget works . (see the attached video)
You can build your own driver extension as I described in my response to this post https://community.ptc.com/t5/ThingWorx-Developers/Using-a-third-party-Jar-file-for-Database-connection/m-p/514861?author_id=269584&collapse_discussion=true&filter=authorId&q=jdbc&search_type=thread
I just found that uploading the jdbc extension works in thingworx 8.3.4. Your post is also helpful. Thank you
