Dear Colleagues,
I've installed a Thingworx 8.4.9 (Tomcat 9.0, Postgresql 10).
When I start Tomcat service, it's being stopped after a several second. Licencerequestfile.txt is also not created so I cannot generate a licence. Could you please support me?
Application Log:
2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ======================================== 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ThingWorx Version Information 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ======================================== 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] majorVersion = 8 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] minorVersion = 4 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] revision = 9 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] build = b45 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] schemaVersion = 1044 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ======================================== 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ======================================== 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ThingWorx System Environment Settings 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ======================================== 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] OS: Windows Server 2012 R2 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] OS arch: amd64 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] OS version: 6.3 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] Total Processors: 8 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] Default encoding: UTF-8 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] JAVA vendor: Oracle Corporation 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] JAVA version: 1.8.0_202 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] JAVA install location: C:\Program Files\Java\jre1.8.0_202 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] JVM Max Memory: 3584 (MB) 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] ======================================== 2020-07-09 15:14:33.305+0200 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: main] WebApp starting... 2020-07-09 15:14:34.690+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] HA mode not enabled. Initializing and starting in standalone mode. 2020-07-09 15:14:34.690+0200 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: main] Default Persistence Provider Name = ThingworxPersistenceProvider 2020-07-09 15:14:34.690+0200 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: main] Default Persistence Provider Package Name = PostgresPersistenceProviderPackage 2020-07-09 15:14:34.690+0200 [L: INFO] [O: c.t.p.p.PostgresDatasource] [I: ] [U: SuperUser] [S: ] [T: main] Reading configuration from configTableCol 2020-07-09 15:14:35.174+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Managers...INITIALIZED 2020-07-09 15:14:35.174+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Database initialization started... 2020-07-09 15:14:35.565+0200 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] System ownership locking started... 2020-07-09 15:14:35.580+0200 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Shutting down the Platform. |
Hi @
Please refer to this article for assistance. If you still have issues following review of the solutions provided, we will need to open a case.
--Sharon
Hi @
--Sharon
Hi @Wojciech.
Did you find the previous post helpful in resolving your issue? If so, please mark it as the Accepted Solution for the benefit of others with the same issue. If you are still having issues, please let us know.
--Sharon
