Helloo community ,
i tried to follow this tutoriel ( https://developer.thingworx.com/resources/guides/analytics-builder-quickstart )
i build the model but when i try to publish it i get always the same error message ( Model deployement failed on connector TW.AnalysisServices.ThingPredictorConnector ) .
i will be thankful if someone can help
Thank you for posting on the Developer Portal.
Have you had the opportunity to review this Knowledge Article from our support portal?
https://www.ptc.com/en/support/article?n=CS269545
Please let me know if that resolves your issue.
Neel
Neel
Thank youuuu , i changed the ports in predictive-standalone.yml and restart ThingPredictor.jar
Regards
I'm glad I was able to help.
Thanks again for reaching out to the Developer's Portal.
Hi, I'm facing the same issue but I can't download the ThingPredictor jar. I'm currently on the hosted trial. Is this something that is not available with the trial. If so, how can I get access?
