Monitoring > Active Edits lists entities that have been closed by the user in ThingWorx
IB_9961693
11-Garnet
Can it be this issue was solved in Article - CS353563 but reappeared in release 9.3.4 ?
I don't see this issue in 9.3.4, closing tabs removes the entities from the Active Edits and this is working in release 9.3.4.
Are you talking about closing a browser with entities in Edit mode? As mentioned in the article it is expected functionality that those entities will still be listed.
Sachin Sharma
After closing tab, the entity is still in active edits list while it's not being edited. If the same developer opens the same entity again he sees in the tab the save button while he did not change anything. If someone else opening the service he gets the popup with 'currently being edited by ...' while the service is already closed.
slangley
(To:IB_9961693)
Hi @IB_9961693.
Have you considered opening a case?  That might be the best approach since Sachin was unable to recreate the issue.
--Sharon
