Moving widgets
gseq
7-Bedrock
Moving widgets
I'm using TW 6.0.3, so this may have been fixed in the later versions.
Once I create a panel and a gauge inside it, can I move the panel group(with the gauge) that i just created into another one? I'm unable to drag/drop.
Thanks.
Aanjan
(To:gseq)
Gerard, the easy way to do so, is select the 'Workspace' tab in your Mashup, click on your panel (that has the gauge), and then cut it. You can then click on the other blank space you would want to move to, and then paste it there.
2 REPLIES 2
Aanjan
(To:gseq)
gseq
7-Bedrock
(To:gseq)
Thank you Aanjan, that worked.
