Mqtt extension "System" user
cbaurand
I'm starting to use Mqtt extension. All works fine. My thing is connected to the broker and i can receive and publish messages. The problem i have is, when i receive a message from the broker, the user that runs the thread is "System". Is there a way to change this user to my own "system" user ?
Thanks for your help,
Cyril.
abjain
(To:cbaurand)
@cbaurand : I think in this case you will have to provided appropriate permission to 'System user' itself as for your own user , you will have to give permission at multiple levels. Please go through the following documentation on how a System user makes management of internal service permission easier- http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FComposer%2FSecurity%2FSystemUser.html
Would also recommend to go through the article: https://www.ptc.com/en/support/article/CS270968
6 REPLIES 6
PaiChung
22-Sapphire I
(To:cbaurand)
I think most likely you are invoking some platform event mechanism causing it to turn as system or superuser which basically has permissions to trigger anything.
I have seen on Timers and Schedulers the ability to run under a certain user.
Now the bad news, I don't know how you can add that to your extension
cbaurand
(To:PaiChung)
@PaiChung You're right, i saw that the subscription called on a mqtt property change is done by the System User. My problem is, this System user doesn't have the visibility on the things i need at this level.
I don't want that this System user gets this visibility. I want that my own user, like a "MqttUser" gets this visibility.
abjain
(To:cbaurand)
cbaurand
(To:abjain)
IF i do what you propose, my System user will have visibility on all of my assets. Isn't it something that breaks the security?
PaiChung
22-Sapphire I
(To:cbaurand)
Since nobody can be logged in directly as system user it is not a threat to your security.
slangley
(To:cbaurand)
Hi @cbaurand
If one of the previous responses helped to answer your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
