I had a situation where the same expression Function to be used in three different labels.
I have three Labels, and three different services as an input to the expression.
@pshashipreetham : You can add multiple parameters in expression functions and the values for these parameters can be from you three services.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Abhinav
