Value stream vs stream?
RajatBain
Can anyone please explain me the differences and when to use which one with example? I have read few articles on this topic but still its not clear to me. I would request you to give an use case scenario. Thanks.
yhan
(To:RajatBain)
We have TWX tutorials video to introduce value streams / streams:
In summary:
  • Value stream is generally used to record one fast-changing data of one thing, such as the speed of the machine, humidity, temperature, etc.
  • Streams are used when you want to combine a specific set of data over time from different sources. And if you are looking to record data over time paired with other relevant data points.
yhan
(To:RajatBain)
In summary:
abjain
(To:yhan)
Hi @RajatBain ,
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Abhinav
