I want to make a value display to display my property value, but when I want to view the mashup, the value display is not visible. I already checked the visible button but still nothing changed
thanks
Hi @AF_10333884.
Based on the todo list, it appears you don't actually have it bound. Here's a link that will help you with that. This expert session is a little old, but it may also be helpful.
--Sharon
Hi @AF_10333884
I did a quick test and it is working properly
Please check on below points :
If you are able to see value in the label widget then we can check on Value Display.
/VR
Hi @Velkumar ,
Sorry im really new to this. How do I know when does GetPropertyValue get executed? can you show me where to look at? And yes my properties has a value. When I try to bind output to label widget, the label appeared but not showing the right value. My value is Number and it only shows "label"
+ i also got this reminder but I don't know where I should put the trigger.
Hi @AF_10333884.
--Sharon
Hi @AF_10333884
Just click on 'GetPropertyValues' service in Composer Mashup Builder. You can see the trigger event in the Binding Tab
/ VR
