My mashup are not opening and they keep on loading continuously
AM_10639709
6-Contributor
Hello
I am using thingworx 9.4.4 and suddenly my mashups has been stuck and they keep on loading without showing anything.
Any help will be appreciated.
Hello @AM_10639709
Can you please share some of the further details?
1) Have you made any recent changes in the system after which you are facing the issue?
2) Is there any custom extension presnt in your application?
There are certain things you can try to narrow down the issues
1) Check if index.html file is missing from the following path \ThingworxFoundation\tomcat\apache-tomcat-9.0.43\webapps\Thingworx\Builder
2) Builder location should not contain unwanted files
3)In case of error on mashup loading on edit check if css and js file used in index.html files exists or not with correct name of the file
 you can also refer the following article for your reference
https://www.ptc.com/en/support/article/CS356827
Hello @AM_10639709
Hello @bchaudhary
Thanks for your prompt response.
1) I have not made any changes as such we have not used this server from quite some time though.
2) Yes we do have some of the custom extension but not sure which one is causing the issue here if its because of custom extension.
