Hello Expert,
I want to create a tootip mashup on the map widget.
So, I create a tooltip mashup refer to the below link.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS230816
but TruckTooltipMash isn't appear on the TruckMash map widget..
By the way I don't know how to bind the parameter exactly.
This seems fine.
Also, add all data from GetImplementingThingsWithData Service to data of Google map widget and select locationfield in the google map property as location.
Also, set show markers as checked.
Just to confirm did you set the OnLoad property for these services as true while adding these Services in the mashup?
Yes.
I set the OnLoad property for GetImplementingThingsWithData Services.
By the way, Above Connection is right?
This seems fine.
Thanks a lot!!!!
Finally Tooltip mashup is appeared!
But Another problem occured ...
Is it a binding problem?
Create parameters for the tooltip mashup and bind those parameters to your widgets.
Now in the main mashup when you will select the tooltip mashup; those parameters will appear as properties. Now bind your tooltip data from getimplementingThingsWithData to the properties that appeared.
