We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Greetings,
Do any Thingworx widgets allow you to navigate to an external web application?
For example, click a button to go to another web application
That depends on what you'd call another web app.
If you want to redirect to another URL with a Button, just add a link widget into the mashup, hide it, and bind the click event of the button to navigate service of link widget.
Or you can create a new responsive mashup, put the web frame widget into it and call that mashup with navigation widget which is more or less a button.
Be careful though, since web frame widget is basically HTML iframe, some sites will not work in it. Hope I helped.
Tomas
Tomas
Ok....feeling pretty dumb right now. I was so focused on the Navigation widget, i didn't see the Link widget.
Thanks.
That happens to all of us from time to time
Glad I helped.
