Dec 18, 2015 9:36 PM UTC
Navigate outside Mashup to external application
Greetings,
Do any Thingworx widgets allow you to navigate to an external web application?
For example, click a button to go to another web application
tcoufalAnswer
Dec 19, 2015 8:39 AM UTC
That depends on what you'd call another web app.
If you want to redirect to another URL with a Button, just add a link widget into the mashup, hide it, and bind the click event of the button to navigate service of link widget.
Or you can create a new responsive mashup, put the web frame widget into it and call that mashup with navigation widget which is more or less a button.
Be careful though, since web frame widget is basically HTML iframe, some sites will not work in it. Hope I helped.
Tomas
tcoufal1-VisitorAnswer
Tomas
rtaylor-31-VisitorAuthor
Dec 19, 2015 1:27 PM UTC
Ok....feeling pretty dumb right now. I was so focused on the Navigation widget, i didn't see the Link widget.
Thanks.
Dec 19, 2015 4:48 PM UTC
That happens to all of us from time to time
Glad I helped.
