Hi All,
How to navigate between (Using browser's Front and back) screens in mashups without using menu button.
Can anyone help on this. I am using Map widgets also in screens.
Kiruthiga, you can use the 'Navigate' widget with TargetWindow set to 'Replace'. This will replace your current Mashup with the selected Mashup (in your current window).
What is your use case here? There might be couple different ways to achieve what you have in mind.
Hi Aanjan Ravi,
Thanks. I have used this navigate widget. But can we bind the mashup name dynamically to that widget
Yes you can, the Mashup Name property it's bindable.
