Navigation function
krishnakomal
Navigation function
Thingworx 8.5.2 :
Navigation mashup has two infotable parameters but I could not see the parameters when I created the navigation function.
I could not bind anything to parameters as I dont see them.
Please resolve the issue asap.Thanks in advance
Hello @krishnakomal,
If you put other parameters in the navigation mashup ( date, number, string) are you able to see the parameters in the Navigation function dropdown ?
I tried for other mashup parameters too.It's the same.Is that a bug in 8.5.2 version?
Would it be possible for you to create a support case for this issue ?
Thank you,
