Hi ,
After clicking on upload button, Is it possible to disable the Upload button available in file Upload widget.
After successful file Upload , Upload button should be Enable.
Hareef
Hi @H_1234.
The release of ThingWorx 9.3.4 was delayed but it is now available on the PTC download site. Hopefully, it will resolve your issue.
--Sharon
Hi @H_1234 ,
This issue is already reported to the R&D. pls check the below linked article:
https://www.ptc.com/en/support/article/cs367391
Let me know if you have anything further.
Regards
Bhawna
Hi @H_1234.
I checked on the status of the internal R&D ticket and found that a new File Upload widget is targeted for ThingWorx 9.3.4 which is expected to be released the end of July. I will monitor the status in order to advise once the release is made available.
--Sharon
Hi @H_1234.
--Sharon
