Need to make a widget visible/invisible from different buttons
bzindy
8-Gravel
I can not make a given widget be hidden clicking on a button and shown clicking on another.
The issue is that the widget visible property can be linked to only one service.
So i tried to create a javascript program
var params = {
  visible: false /* BOOLEAN */
var result = me.OkButton_visible(params);
But it does not modify anything.
Can someone share with me the right way to do that?
Cheers
Bruno
ttielebein
(To:bzindy)
Wait, what exactly is the use case? Can you create a toggle visibility service that can then be triggered by both on-click events? Then this one service can be bound to the isVisible property. Hope this helps!
2 REPLIES 2
ttielebein
(To:bzindy)
Thanks Tori, you got what i needed indeed. What you presented should work just fine i believe.
Just one more question, is there a way to identify through some javascript functions what is the origin of the alert that triggered a service?
Cheers
Bruno
