Need to remove line color from grid
bgupta-2
Dear Team,
I need to remove line color from grid.
I do n't want to show row line. How can we do?
Dear Bhuwaneshwar Gupta​,
You can use Grid Advanced Widget in your mashup and configure its properties as mentioned below to achieve the required.
1) Select Grid Advanced Widget
2) Customize its 'RowFormat' property
             Make a new custom Style Definition for this property and Set Line Color to white as highlighted in below screenshot.
3) Customize the 'RowAlternateBackgroundStyle' property
4) Save and refresh the mashup. The grid on mashup will be like this
Hope it helps
Following up with you on the original question posted here, can you please indicate if any of the recommendations given above answered this for you?
If the above post adequately answered your question, you can mark the reply as the "Correct Answer."
Or, if you are still unresolved on your original question, let us know and we can continue troubleshooting this with you.
This feedback is a key step toward ensuring Community users with a similar issue are able to locate the information they need.
Himanshu
