HI Team,
I have a button on which I gave custom class and using root of it, I am able to change its background color, but I am unable to change font-size of that button.
I tried to change it via many things, but its only changing when I am expanding #shadow-root (open) and changing value under <style ctx="PTC-BUTTON.danger"> [part~=label] {
font-size: 18px}
I am not able to use it in custom css as I am not aware how to use ctx in custom css.
Can anyone please guide me on it?
My current css is:
.classqa, #root_ptcsbutton-150{
background: #d91717
Hello @VK_10159720
Pls check the following article, In this you may find the solution:
https://www.ptc.com/en/support/article/cs322901
Bhawna
There is no need to do this using CSS, you can change the background color and font size of the text using the built in functionality.
This is also the recommended way by PTC.
Background color:
Font size:
Perhaps if you use a lower version of Thingworx this might not be possible. But if I remember correctly it should at least be possible from 9.1.
Jens
HI @jensc,
It is not picking mentioned font-size in style properties as per your suggestion. It is displaying some different values. I even tried to remove style theme as well, but didn't help. but if i refresh the mashup in runtime, then it takes correct value as specified in style properties.
That is why I had to change via css.
Hello @VK_10159720 ,
Have you tried the shared article?
If that is not providing the expected solution. In my opinion, pls open a case with Tech support team.
Bhawna
Hello @VK_10159720
Alright, I think I have seen that sometime before as well, although for my case it was in a list.
For me it was something in the Style Theme that I had to change.
But if the out of the box functionality is not working for you as it should, I would as @bchaudhary is saying, open a case with PTC to figure it out.
Jens
Thanks both. Will Check with PTC.
I tried multiple things using above article but it keeps on giving error.
