I am looking for Thingworx 9.7 Helpcenter, Can anyone please share the link or guide pdf?
Hello @KV_10974131
You can check the attached link for your reference:
Kindly revert if you have any further questions!
Bhawna
Hello @KV_10974131
Bhawna
Hi @KV_10974131,
While I am aware that you already received the Help Center link in a post below, I believe it is also good to be aware that the Help Center link is included in the product, specifically in Composer, as you can see below.
