We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Hey,
I would like to know if there is a way to get the children of a node inside a network programaticaly.
So, let's say in my network I have parent A and I want all its children programmaticaly.
How would i do that in javascript ?
Hi Frederik,
You can use the GetChildConnections code snippet as shown below. The name parameter will be the name of the node to return child connections for.
var params = {
name: undefined /* STRING */
// result: INFOTABLE dataShape: NetworkConnection
var result = Networks["MyNetwork"].GetChildConnections(params);
Hi Frederik,
var params = {
