Network builder tree runtime
fmanniti
9-Granite
Hi, in order to make a network tree in composer there is a wonderful widget where you drag and drop from a list of entities to a tree and you can "manually" move them and create the parentals relationships.
Is there a kind of widget like that also for Runtime?
5 REPLIES 5
posipova
20-Turquoise
(To:fmanniti)
Not out of the box. But you may look into custom extensibility and development - attached some reference documentation.
ankigupta
(To:fmanniti)
Hi Fabio Manniti​,
In addition to what Polina Suggested; you may also try to use existing list and tree widget with a add button.
Selected list item will give the child to be added and selected tree item will give the parent.
Then we can create a custom service (which takes the above parent and child) to add a new row with this. And we can add a button to call our custom service.
I hope it helps.
Yes, this is what I am doing right now. I just asked because the "drag and drop" thing is something more 'captivating' for users but of course it is a way.
Thank you.
ankigupta
(To:fmanniti)
Hi Fabio Manniti​,
I agree with you. You may want to look into custom extensibility and development as suggested by Polina to achive this feature.
Yes, I will probably do that in the future. Thank you very much
