No SSL certification in C SDK
ShengLiangQiu
Just a simple method to disable SSL certification in the SteamSensor sample in C SDK, for those who wants to use that in development mode or show to customer, as you may know use twApi_DisableCertValidation() function will not work:
1. Locate the src/config/twConfig.h in the SDK file, add:
#define USING_NO_TLS
#undef USING_AXTLS
right after #define OFFLINE_MSG_STORE 1, the result should be like:
2. Locate  the src/tls/twTls.h in the SDK file, modify #include TW_TLS_INCLUDE to include more condition:
#if defined USING_AXTLS
#include "twAxTls.h"
#elif defined USING_NO_TLS
#include "twNoTls.h"
#else
#endif
and the result should be like:
After all these are done, compile your code and start, you will connect to your Thingworx server without SSL.
4 REPLIES 4
Although we provide this capability to make development easier, never deploy the EMS in production without SSL.
Agreed, I was asked about how to disable the SSL in the C SDK several times for demo purpose in the past couple of months, just for those who need this.
Why do you say twApi_DisableCertValidation() does not work?  What that does is prevent the checking of the certificate entries to ensure they match those that are set using twApi_SetX509Fields().
If you want to disable checking valid signing authority of the certificate so that you can use self-signed certificates for demo purposes, you should use the function twApi_SetSelfSignedOk().
If you want to induce MAJOR SECURITY RISKS by disabling encryption altogether then you would use USING_NO_TLS.  This should only be used in very limited circumstances where the edge and ThingWorx server are deployed inside a firewall within the same security domain and where deep packet inspection of all traffic is a requirement (i.e. some military installations may require that)
"It's just a demo" is never an excuse to not use encryption. The ThingWorx server ships with self-signed certificates (at least it used to, even if not, it is a simple single command to create one), so using TLS requires very, very little extra effort.
Yes, you are right, not using ecryption shouldn't be recommanded.
I have done several tests with the combination of twApi_DisableCertValidation() and twApi_SetSelfSignedOk(), but seems that doesn't work if you don't use SSL on Thingworx server side, so my purpose is just to give a way for those who doesn't want to use SSL at server side for presales demo.
