Not Able to Register RemoteThing on EMS using Lua Script
Regular Member
Hi Team -
I am trying to run the Respberry Pi example from the Guides.
Everything is working fine and my TW Server, EMS Server and LuaResource is talking to each other.
However - LuaResource is NOT able to register the RemoteThing on EMS server.
Its getting stuck at
[DEBUG] 2018-03-01 15:13:19,864 thingworx.server: Invoking /Thingworx/Things/LocalEms/Services/AddEdgeThing on server. content: {"keepalive":60000,"port":"8001","timeout":15000,"host":"127.0.0.1","proto":"http","name":"*ExampleThing","path":"/scripts/Thingworx"}
[TRACE] 2018-03-01 15:13:19,865 luaBindings:newRapClient: Found RAP at 127.0.0.1:8080
[TRACE] 2018-03-01 15:13:19,865 luaBindings: Got RAP timeout: 0
[TRACE] 2018-03-01 15:13:19,865 luaRapBindings: Self Signed certificates are enabled for the RAP conneciton.
[TRACE] 2018-03-01 15:13:19,865 luaRapBindings: Certificate validation is disabled for the RAP conneciton.
[DEBUG] 2018-03-01 15:13:19,866 SDK: twTlsClient_Create: Initializing TLS Client
it makes a call to EMS server and waits for sometime and EMS server closes the twTlsClient.
Any suggestions pls? Attached is Config.jason and Config.lua files...
Tags (2)
Re: Not Able to Register RemoteThing on EMS using Lua Script
The Raspberry Pi Quickstart guide has been updated with a link to download the latest version of EMS and instructions for connecting to the hosted trial ThingWorx instances that now use https.
https://developer.thingworx.com/resources/guides/thingworx-raspberry-pi-quickstart/install-ems
Per our messages, it also sounds like the ThingWorx SDK was a better solution for you.
-- Craig A.
Thanks Craig. Yes.. I think rather than investing so much time in EMS and learning Lua Script, its best to use C or Java SDK. It gives you more control.
BTW - I am not able to figure out what was changed in EMS server new documentation?
Craig - Its still not working - Same Issue !
Were you able to connect to your EMS expert in Germany?
I am also facing the same problem.
Running lua script in raspberry pi stuck at
[INFO ] 2018-12-14 21:36:56,534 thingworx.handler: Creating a new handler.
[DEBUG] 2018-12-14 21:36:56,538 thingworx.server: Invoking /Thingworx/Things/LocalEms/Services/AddEdgeThing on server. content: {"keepalive":60000,"port":"8001","timeout":15000,"host":"192.168.1.101","proto":"http","name":"PiThing","path":"/scripts/Thingworx"}
[DEBUG] 2018-12-14 21:36:56,538 SDK: twTlsClient_Create: Initializing TLS Client
Kindly help...!!!
