Hello
I have infotable mashup parameter and i want to transfer it from one mashup to another. Is there a specific way to it?
Any help would be appreciated
Hello @KV_10974131 ,
This can be resolved by following the article:
https://www.ptc.com/en/support/article/CS378392
https://www.ptc.com/en/support/article/CS317783
Also, you can follow the community post:
Kindly share if your issuestill persists.
Regards
Bhawna
Regards
Bhawna
Hello @KV_10974131,
It looks like you have a response on your topic. If it helped you solve your issue, please mark the reply as the Accepted Solution.
Community Moderation Team.
