Not able to get output from 'GetDrawing' action in Thingworx Flow
Velkumar
Hi all,
I have created a workflow in TWX flow, when I use 'GetDrawing' action for Windchill I'm not getting any output. PFB PNG for reference.
/VR
Velkumar
(To:gnandyala)
Hi @gnandyala
We have solved the issue. Issue is due to configuration issue.
/VR
gnandyala
(To:Velkumar)
Hi Pearl,
Do you see any error while dragging it.
Thank you,
Gautham
Velkumar
(To:gnandyala)
Hi @gnandyala
No I didn't see any error.
/VR
gnandyala
(To:Velkumar)
Velkumar,
Will update you by looking into 'GetDrawing' functionality.
gnandyala
(To:gnandyala)
Hi Velkumar,
Which version of ThingWorx flow are you using.
Thank you,
Guatham.
Velkumar
(To:gnandyala)
Hi @gnandyala
/VR
