Not able to install thingworx flow getting 502 Errors?
AM_10639709
6-Contributor
Hello
I am trying to install Thingworx flow on My Twx foundation 9.3.6 but it is failing with following error
TypeError: Cannot read property 'statusCode' of undefined
    at /opt/ThingWorxFlow/modules/ux/dist/helpers/twxUserHelper.js:25:285
    at Request._callback (/opt/ThingWorxFlow/modules/ux/dist/helpers/twxUserHelper.js:8:977)
    at self.callback (/opt/ThingWorxFlow/modules/ux/node_modules/request/request.js:185:22)
    at Request.emit (events.js:314:20)
    at Request.onRequestError (/opt/ThingWorxFlow/modules/ux/node_modules/request/request.js:881:8)
    at ClientRequest.emit (events.js:314:20)
    at ClientRequest.onConnect (/opt/ThingWorxFlow/modules/ux/node_modules/tunnel-agent/index.js:168:23)
    at Object.onceWrapper (events.js:421:26)
    at Socket.socketOnData (_http_client.js:508:11)
    at Socket.emit (events.js:314:20)
    at addChunk (_stream_readable.js:297:12)
    at readableAddChunk (_stream_readable.js:272:9)
    at Socket.Readable.push (_stream_readable.js:213:10)
    at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
Uncaught exception: TypeError: Cannot read property 'statusCode' of undefined
On UI I can see 502 Bad Gateway . Any help will be appreciated.
Velkumar
(To:AM_10639709)
Velkumar
(To:AM_10639709)
slangley
(To:AM_10639709)
Hi @AM_10639709
Is it failing on installation or login?  Which version of ThingWorx Flow did you install?
--Sharon
