im not able to relicense my thingworx 8.4 with eclipse extension.
When I try to license thingworx via Licensing subsystem, I get the following error:
Seems to be an issue with trusted storage and this need to be verified in a Support case.
Please open a case with PTC Support.
Thank you,
Raluca Edu
Hi @vartush.
It sounds like you are either using a license for another system or something happened to change your Device ID. If ThingWorx is running, log in to Composer and browse to Subsystems > Licensing Subsystem. Select Services and execute the GetInstanceID service. This will return the Device ID to be used for generating a new license.
If you're unable to perform the above steps, a case will be needed to work through the issue. I will be happy to open one on your behalf.
--Sharon
Hi @vartush.
If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
