Hello
I am using thingworx 9.5 and it was working fine till yesterday , but i am not able to edit this particular mashup from morning . It keeps on loading when i try to open it.
Any help will be appreciated.
Articles:
Articles:
Hello @KV_10974131
Kindly check the following queries:
1. Have you made any changes into the system/ configuration?
2. Have you tried opening the Mashup in any other browser/ incognito mode?
3. Pls share if you are seeing any error on the Mashup.
Bhawna
