Hello
I am creating a mashup over which i want to shown my cloumn data as a graph . Can you please share a way to do it ?
Any help would be appreciated
Thingworx supplies many kinds of chart widgets usually using infotable as data source.
Please refer to below links for details.
You can also search help center with "chart widget" keyword so you can see all the chart widgets.
Hello @KV_10974131 ,
Are you trying to create a graph using in your Mashup? Can you pls provide additional details?
Bhawna
