Where I can give the permission to a non administrator user to solve the following error in Application logs.
Not authorized for ServiceInvoke on ForwardEvent in PersistentSession
Thank You!
Thank You @raluca_edu ,
Resolved the issue
After giving visibility Permission to organization containing user for the following entities.
1- PlatformSubsystem
2- BaseTheme
3- dropdownArrow
4- EntityService
Now it works fine.
Best Regards!
Naeem
Please grant access rights for that user on Things Collection/Mashup:
Hope it helps,
Raluca Edu
Now that error in Application Logs has been resolved.
But ....
I'd like to see the mashup set as HomeMashup of the user, Gave the visibility and run time permission of things included in mashup to the user, but not able to see the mashup.
And seeing following message
[message: Entity Not Found : [PlatformSubsystem]]
Gave the organization visibility permission to PlatformSubsystem
solved ---> [message: Entity Not Found : [PlatformSubsystem]]
Now Getting --> [message: Entity Not Found : [Base Theme]]
Thank You!
Resolved the issue
2- BaseTheme
3- dropdownArrow
4- EntityService
Now it works fine.
Best Regards!
Naeem
But ....
Thank You!
