Not showing any services under Datatable in ' Data' tab of Composer (Thingworx 9.1)
VaibhavShinde
Hi
I am facing an issue that Services are hidden in Data tab as in below image. but all bindings are there and working as expected but it was sudden change and i am not able to see the services also i tried to add new service but still its hidden . Please help me to resolve this.
5 REPLIES 5
Hi @VaibhavShinde
Are you seeing this behavior only with a specific mashup or across all the mashups?
Have you tried with other browsers?
Sachin
Hi @SachinSharma ,
I am facing this with specific Mashup not across all mashup . I tried on other browser but still its not working.
regards,
Vaibhav
@VaibhavShinde
Please try following steps and see if it fixes the issue,
1. Make a copy of the mashup and also take an export of it.
2. Delete and reimport the mashup and check if the services are visible or not.
Sachin
Hi @SachinSharma ,
I tried As you said delete and import  but Still Not Working .
regards,
Vaibhav
Can you try removing the thing from data tab and save the mashup. Edit the mashup again and add the Thing\service in data tab and see it works.
Sachin
