Hi all
I have a datatable where devices are stored , i'am building a notification system where when device goes online it will send a notification email similarly for when device went offline . The issue is the email should be send after xx minutes i.e a delay say 15 min or more for different devices have different delay. To do this i have subcribed to timer event and timer runs for every 1 min .
So i have acheived the delay as nowtime >=time device went online/offline + (15 minutes delay) . when email is beingsent i'am updating some flags that this device is notified or not for online/offline . Issue here is i get notified but sometimes i got multiple notications (rare case). Is this a feasible solution for this or i should go for db instead.My datatable list isn't that big so i prefered at TW Side .
Any thoughts on this highly appreciated.
You should have some bug on your code, I have exactly the same configuration type and it works smoothly.
Thanks for the reply Carles
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
