Number of rows in Thingworx Analytics has a value of zero
Nuttapol
11-Garnet
When i generate a new dataset, the number of rows tab has a value of zero
  These are CSV File and json code
        "dataType": "DOUBLE",
        "description": "C",
        "displayOnly": false,
        "fieldName": "C",
        "lever": false,
        "objective": false
        "description": "D",
        "fieldName": "D",
        "lever": false,
        "objective": false
        "description": "E",
        "fieldName": "E",
        "lever": false,
        "objective": false
        "description": "F",
        "fieldName": "F",
        "lever": false,
        "objective": false
cmorfin
(To:Nuttapol)
Hi Nuttapol
The issue (or at least one that woudl lead to 0 rows showing) is that you have no field defined as goal in the json file.
You need to have at least one field defined as goal ("objective": true ), so that the engine knows what to predict.
Without a goal, the dataset is indeed loaded as 0 rows.
Hope this helps
Kind regards
Christophe
5 REPLIES 5
jgreiner
(To:Nuttapol)
Hi Nuttapol,
I have 2 questions to help me troubleshoot this issue:
  1. what version of ThingWorx Analytics Builder are you using?
  2. Are there any errors in the Application Log file in you ThingWorx Composer?
Thanks and Please Advise,
John
John GreinerThank you for answer
1. I use trial version
2. It don't have update log file when i  upload dataset
cmorfin
(To:Nuttapol)
Hi Nuttapol
Hope this helps
Kind regards
Christophe
Thank you so much Christophe Morfin
cmorfin
(To:Nuttapol)
Hi Nuttapol
I am happy it worked for you.
If you do not mind, it would be useful if you could mark the reply as correct answer so that others facing the same issue will be able to easily find the solution.
Thank you
Kind rgeards
Christophe
