I have two questions for the OPC UA Client by Labs.
1. How can I address arrays in the configfile for the OPC UA Client?
2. It is intended that OPC UA Client will also support method calls ofn the OPC UA Server?
Thank you.
Hi @nanpat.
Unfortunately, the OPC UA Client extension is not supported by PTC, but perhaps someone else in the community has experience with the functionality you need.
As an alternative, you could use the marketplace extension as a starting point for creating your own extension with the functionality you need. Refer to the ThingWorx Extension Development Guide for assistance.
--Sharon
Hi @nanpat.
--Sharon
Thanks for the quick answer.
That's really a pity. I hoped for something like the functionality like the ODataConnector.
