Sorting an infotable based on order specified
polasaikrishna
6-Contributor
I am trying to sort an infotable result set based on specific order (array)
Example:
My Infotable result set:
Column1 Column2 Column3
d desc1 desc one
h desc2 desc two
f desc3 desc three
t desc4 desc four
My order to sort  ::  [f,t,h,d]
Expected result set after sorting
f desc3 desc three
t desc4 desc four
h desc2 desc two
d desc1 desc one
Would highly appreciate a quick turnaround.
Thanks in advance.
Not super efficient, but should work:
function sort(array,sortOrder,sortColumn) {
    function sortFunc(a, b) {
        return sortOrder.indexOf(a[sortColumn]) - sortOrder.indexOf(b[sortColumn]);
    var temp = [];
    for each(row in array.rows) temp.push(row);
    var nItems = array.rows.length;
    for (var i=0;i<nItems;i++) delete array.rows[0];
    temp.sort(sortFunc);
    for (var i=0;i<temp.length;i++) array.AddRow(temp[i]);
sort(result,['f','t','h','d'],'column1');
    var temp = [];
Thanks Carles it worked :)
Hi @CarlesColl
I have one more additional requirement for info table sorting.
My sort array may not have all the values in the specified column. Only specified values of column must be sorted at beginning and remaining as per existing order.
Example:
Example:
d desc1 desc one
h desc2 desc two
f desc3 desc three
t desc4 desc four
My order to sort  ::  [f,t]
f desc3 desc three
t desc4 desc four
d desc1 desc one
h desc2 desc two
Thanks in advance.
You have the clues on my previous post, just analyse it and adapt to your use case ;)
