Can you suggest Thingworx get the values from OSI PI and push the data into Kepware?
Thanks in Advance.
Please check this article: https://www.ptc.com/pt/support/article?n=CS316167
First you need to create connection between OSI PI and Thingworx and after, connect Kepserver with Thingworx.
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Hi @karthik24.
If you are satisfied with the response from @raluca_edu, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
