On/Off Button
ptc-6292144
3-Newcomer
On/Off Button
Is there a widget that creates an easy On/Off button if wanting to turn options within a mashup on or off? For example, on a mobile device, you can go to settings and quickly turn things on or off by tapping a sliding button. I tried using the slider widget but I can't made the slider bigger (vertically, if I pull the size out the slide does get longer horizontally) and because it is so small it does not work well on mobile devices for user interaction.
paic
(To:ptc-6292144)
You can use the Radio Button widget which is actually a 'button bar' type.
Also to save space for these options, you can either use the option that exists on Headers/Footers or Left and Right side bars that allow them to collapse and expand, or use the Folding Panel widget.
