Is there a widget that creates an easy On/Off button if wanting to turn options within a mashup on or off? For example, on a mobile device, you can go to settings and quickly turn things on or off by tapping a sliding button. I tried using the slider widget but I can't made the slider bigger (vertically, if I pull the size out the slide does get longer horizontally) and because it is so small it does not work well on mobile devices for user interaction.
