On clicking checkbox need to add filed in chart
bgupta-2
On clicking checkbox need to add filed in chart .If we uncheck check box. so respected field should remove from chart.
10 REPLIES 10
liliu
(To:bgupta-2)
Hi  Bhuwaneshwar,
You need a customized service. Please check my sample.
Sorry, I was in a hurry, and if the sample is not detial enough, just let me know
Lily
Hi Li Li Liu,
Thanks.Can U send me each step? I am missing something.
Hi Li Li Liu,
Can you provide me each step?
ankigupta
(To:bgupta-2)
Hi Bhuwaneshwar Gupta​,
You need to actually play with the Infotable.
1. Take the checkbox(s) as input parameters for a Service.
2. In the service; get the call the service to retrieve the data like getDataTableEntries.
3. Now based on what is unchecked; remove the field/column from the infotable.
4. Now in Mashup; bind the service with TimeSeries chart.
Hi Ankit,
As mentioned step done already, I am getting error during testing service . Kindly go through attached screen shot.
ankigupta
(To:bgupta-2)
Is chartTable a dataTable? If you are using some other entity for data; call the corresponding service to get the Data in the Infotable.
If it's a DataTable, service name is GetDataTableEntries.
Thanks Aniket,
I have tried using Datatable that error is not showing but nothing showing on chart.Capture4.PNG
ankigupta
(To:bgupta-2)
Bhuwaneshwar Gupta​, There is no option for x axis. Does the infotable have one column as DateTime?
Second if we run the service by testing in the Thing; does it return data?
NO data on running service.
ankigupta
(To:bgupta-2)
Try adding Data to the DataTable so that it shows in the TimeSeriesChart
