On clicking checkbox need to add filed in chart .If we uncheck check box. so respected field should remove from chart.
Hi Bhuwaneshwar,
You need a customized service. Please check my sample.
Sorry, I was in a hurry, and if the sample is not detial enough, just let me know
Lily
Hi Li Li Liu,
Thanks.Can U send me each step? I am missing something.
Hi Li Li Liu,
Can you provide me each step?
Hi Bhuwaneshwar Gupta,
You need to actually play with the Infotable.
1. Take the checkbox(s) as input parameters for a Service.
2. In the service; get the call the service to retrieve the data like getDataTableEntries.
3. Now based on what is unchecked; remove the field/column from the infotable.
4. Now in Mashup; bind the service with TimeSeries chart.
Hi Ankit,
As mentioned step done already, I am getting error during testing service . Kindly go through attached screen shot.
Is chartTable a dataTable? If you are using some other entity for data; call the corresponding service to get the Data in the Infotable.
If it's a DataTable, service name is GetDataTableEntries.
Thanks Aniket,
I have tried using Datatable that error is not showing but nothing showing on chart.
Bhuwaneshwar Gupta, There is no option for x axis. Does the infotable have one column as DateTime?
Second if we run the service by testing in the Thing; does it return data?
NO data on running service.
Try adding Data to the DataTable so that it shows in the TimeSeriesChart
