I have an organisation where All Things Permission is based. I need to change the name of the Organisation, so I need to create a new one.
But is there any other way to transfer the Permissions level without editing permissions for all Things and mashups?
The only way I can think of is to use a Service/Script to read from one and apply to other.
May be you can try, exporting all as XML, search for the old org and replace with new, using any Editor, and reimport the XML.
Hi @Bikash_Panda ,
That's a good work around but, Risky one. Will give a try this week.
