I am working on a mashup that displays a list of parts. For each part its thumbnail is visible along with name and part number. This mashup requires a button that downloads an excel file containing the parts details: thumbnail image, name and part number.
Like this mockup:
I am able to retrieve the thumbnail in the mashup as described in
Article - CS306799 How to display Visualization data from Windchill in Thingworx mashup via Thingview widget.
My question is can the thumbnail image used in the mashup be included in an exported excel file? If so, how?
The desired output would look something like this:
TIA
Hi @mariaSutton ,
No from Thingworx, may be you can build an Custom Extension on Java which can do that.
Hi @mariaSutton ,
As of now, that feature is not available in the Thingworx, or any workaround to do it.
Is there any other way of exporting images to perhaps word, pdf, etc?
Maria
Hi @mariaSutton ,
