Hi Everyone
I am having a problem with the open weather app tutorial. I have followed the tutorial but i get an error when testing the code. I have created my own API key using the link in the tutorial. I didn't know if there may be an issue with having copied the code from the PDF and whether formatting has been lost.
See error below
Wrapped org.apache.http.conn.HttpHostConnectException: Connect to api.openweathermap.org:80 [api.openweathermap.org/178.62.207.82, api.openweathermap.org/178.62.223.38] failed: Connection timed out: connect Cause: Connect to api.openweathermap.org:80 [api.openweathermap.org/178.62.207.82, api.openweathermap.org/178.62.223.38] failed: Connection timed out: connect
And the code i'm using below
var stringLocation=location+" ";
var arrayLocations=stringLocation.split(",");
var lat=arrayLocations[0];
var long=arrayLocations[1];
//Modify the open weather url here if you are using your own API key
var params = {
url: "http://api.openweathermap.org/data/2.5/forecast?lat="+lat+"&lon="+long+"&units=imperial" +"&type=accurate&mode=xml&APPID=75239107b41bd2c2a72e2e3c7b89b550" /* STRING*/,
timeout: 160 /* NUMBER */
// result: XML
var xmlPage = Resources["ContentLoaderFunctions"].LoadXML(params);
var params = {
infoTableName : "InfoTable",
dataShapeName : "OpenWeatherFeed"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"),dataShapeName:STRING:INFOTABLE(OpenWeatherFeed)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var from_today_value=xmlPage.forecast.time[0].@from.substring(0,10);
a.logger.warn("from_today_value= "+from_today_value);
for each (var item in xmlPage.forecast.time) {
var row = new Object();
var from_current_value=item.@from.substring(0,10);
row.WindDirection = item.windDirection.@name;
row.WindSpeed=item.windSpeed.@mps;
row.WeatherTemp=parseFloat(item.temperature.@value);
row.WeatherHumidity=parseFloat(item.humidity.@value);
row.From=item.@from;
row.To=item.@to;
row.Title=xmlPage.location.name+" "+xmlPage.location.country;
row.Precipitation=(item.precipitation.@type+" "+item.precipitation.@value)==" "?"NoPrecipitation":item.precipitation.@type;
result.AddRow(row);
Thanks Matt
Hello Everyone
Turned out the issue was with the firewall blocking access to the open internet here at work
Thanks Matt
Are you sure that is the right API Key? Also, have you made sure that everything rendered right, like even newlinee characters? I have had issues copying from PDFs into ThingWorx in the past
Hello Everyone
Thanks Matt
Can you mark this answer as correct to help others find the answer to their problems more easily? Thanks, and glad to hear you got it working!
