I am trying to configure Directory Services in Thingworx and AD service in AWS EC2. Even, thingworx is running in the same server but i am getting error like,
'Authentication attempt #1 FAILED for [user = Administrator]: Invalid Password".
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<Entities build="33" majorVersion="5" minorVersion="0" revision="2" schemaVersion="773">
<DirectoryServices>
<DirectoryService className="com.thingworx.security.directoryservices.LDAPDirectoryService" description="Wipro Flex Thingworx Directory Service" documentationContent="" enabled="false" homeMashup="" lastModifiedDate="2014-08-20T17:20:39.620-04:00" name="WiproFlex" priority="1" tags="">
<Owner name="Administrator" type="User"/>
<avatar/>
<DesignTimePermissions>
<Create/>
<Read/>
<Update/>
<Delete/>
<Metadata/>
</DesignTimePermissions>
<RunTimePermissions/>
<VisibilityPermissions>
<Visibility/>
</VisibilityPermissions>
<ConfigurationTables>
<ConfigurationTable description="LDAP Settings" isMultiRow="false" name="LDAPProxyConfiguration" ordinal="0">
<DataShape>
<FieldDefinitions>
<FieldDefinition aspect.defaultValue="389" baseType="NUMBER" description="LDAP Server port" name="port" ordinal="0"/>
<FieldDefinition aspect.defaultValue="uid=admin,ou=system" baseType="STRING" description="LDAP Distinguished Name to use when binding" name="adminBindDN" ordinal="0"/>
<FieldDefinition baseType="PASSWORD" description="LDAP administrative password" name="adminPassword" ordinal="0"/>
<FieldDefinition aspect.defaultValue="ou=people" baseType="STRING" description="User Base DN" name="userBaseDN" ordinal="0"/>
<FieldDefinition aspect.defaultValue="localhost" baseType="STRING" description="LDAP Server" name="server" ordinal="0"/>
<FieldDefinition aspect.defaultValue="uid" baseType="STRING" description="LDAP user id attribute to match when looking up a user" name="userIdAttribute" ordinal="0"/>
</FieldDefinitions>
</DataShape>
<Rows>
<Row>
<port>389.0</port>
<adminBindDN>
<![CDATA[DC=AdminDC,CN=AdminCN]]>
</adminBindDN>
<adminPassword>
<![CDATA[ugd08BRQrg5gmA1yOvImaw==]]>
</adminPassword>
<userBaseDN>
<![CDATA[DC=UserDC]]>
</userBaseDN>
<server>
<![CDATA[<Directory Server IP>]]>
</server>
<userIdAttribute>
<![CDATA[User Name]]>
</userIdAttribute>
</Row>
</Rows>
</ConfigurationTable>
</ConfigurationTables>
<ConfigurationChanges/>
</DirectoryService>
</DirectoryServices>
</Entities>
Configuration File Attached.
The message seems to say that the User name / Password you provided is incorrect.
You are pointing to a 'node' in AD and are using a permitted User/pwd within that node and its children correct?
Are you sure there are no special characters in the password which LDAP can't handle? For instance, colons almost always cause issues.
