I would to improve my map application on Mashups.
I saw that the widget has many properties to setting up shown regions, routes, etc.
But, the user guide of this widget has little information about these configuration.
So, to start this discussion: How to modify the initial zoom of the map shown in the mashup?
Christyam
There is a developer guide for the Google Street map widget which has many of the same properties as the OpenStreetMap widget:
https://developer.thingworx.com/resources/guides/google-map-widget-how/widget-maps-properties
The initial zoom level is set with the 'Zoom' property which defaults to 8. Zoom level 1 shows almost all the world and zoom level 18 shows individual houses and businesses.
You can get more information about how different properties are used by hovering over them to make a description pop-up appear
