I would like to use the OpenStreetMap Widget with custom styling, instead of using blue for water i would like it to be black etc to match closer to the dark theme we are using.
Using Google Maps Widget is not an option as it has a cost associated Per Click.
Can this be done through some custom CSS?
Hi @Fuegosan.
The widget available through the Marketplace does not support styling, and unfortunately it is not supported by the ThingWorx team. You might be able to customize the widget but we would not be able to provide any guidance, if needed.
Regards.
--Sharon
Hi @Fuegosan.
Regards.
--Sharon
Hi @Fuegosan.
If my previous response answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
