Hi
I have a DefaultPageMashup selected on my Master. When I try to open Master it does not open any mashup.
This feature was available in 4 version.
Is there a workaround?
Sabarish
Sabarish,
Are you opening the Master from Composer (i.e. 'View Mashup')? If so, you need to remove the extraneous "&mashup=". After removing this from the URL, your Mashup will load as expected.
Adam
Thanks Adam. That worked.
Previously, the Link used to include the mashup as well.
Now it is enough only if we give the link removing the &masup to the users.
